Put the 3 ton stands on some cribbingFor those of you that installed taller coils like carli or thuren, were 3 ton jack stands tall enough to get the truck up and drop the axle or did you have to use 6 ton? Thanks.
I only did the brake line anker point on the axle.Did anyone have to unhook axle breather tube or just the abs/brake lines to drop it enough?
Same here.I only did the brake line anker point on the axle.
The stock axle hight is less than 12” off the ground a standard 3 ton stand reaches 20” plenty of reach plus can be cribbed under the stand, if he was doing it lots id recommend bigger stands but for a one time thing no need to spend the money.... here is my 3 tons and 6 tons in comparison when building my flat deck the frame rails are level and 20” off the groundObviously the measurement methods being used are unreliable. I don't think my 3 ton stand would reach the axle on stock tires. The 6 tons might have worked, but I used my 12 ton stands which max out at 28".
FYI, jack stands capacities are rated by the pair, not singles.
^ thisObviously the measurement methods being used are unreliable. I don't think my 3 ton stand would reach the axle on stock tires. The 6 tons might have worked, but I used my 12 ton stands which max out at 28".
View attachment 12465View attachment 12466
I prefer cinderblocks lol super safe especially if used with the hollows horizontal lol^ this
All jack stands made after 2015 are rated as a pair per ASME PASE-2014
YMMV lolI prefer cinderblocks lol super safe especially if used with the hollows horizontal lol
