I just added a Bilstein 2" level kit with the reservoir 5160's to my 2019 2500 Reg Cab Long Bed Hemi Tradesman. Also added matching rear shocks and a 1" rear spacer (wanted a little rake). Also used an RC adjustable track bar and the RC steering box brace. My brother is an ASE mechanic with a side home business and did most of the work for me. I helped for a bit but I left the truck with him overnight and he was able to get my truck to his normal local alignment shop before I thought to talk to him about the specs for alignment that thuren recommends. That's on me but I've got a couple questions about what came back from the alignment shop. They are recommending offset ball joints to correct the camber and this isn't something I ever ran into researching level/lifts on these trucks. My brother has a great relationship with the alignment shop and for the price they/he is charging me I'm completely good with having it redone to thuren/CJC specs but the alignment shop doesn't think it will have any affect on the camber issues. Here are the specs they gave me from the alignment.
The Thuren/CJC specs call for 0.00-.05 total toe and 3.5-4 caster for 2019 hemi trucks. So I'm pretty close on the caster but not so much on the toe. Has anyone else run into this issue? This truck only has 4K miles on it and I'd hate to swap out the ball joints for offset balljoints if they aren't needed at this 2" lift height.
Otherwise I love how everything worked out. Went with 285 75 18 Falken Wildpeak at3w on Level 8 Hauler 18x9 0 wheels. I know the wheels offset isn't ideal but with the skinnier "35's" they end up just covered by the mopar offroad style flares.
