Lets see your DRW with aftermarket wheels
Linked4door
Looking to get some ideas on possibly changing out my OEM wheels. Not sure what is out their with this new 8x200 bolt pattern and would like to see what y'all are running. Has anyone put a set of 19.5's on yet? Please post pics, and specs of the wheel/tire/suspension setup you have.
Ford has been running 8x200 since 95ish so there is a ton of wheel options….
The main reason is I really wanted to see wheels on our trucks to get a better idea what it would look like on a ram.
Appreciate that info about the fords sharing the same bolt pattern. Do you know if they shared the same size hub bore and backspacing?
I believe so but not 100% sure, i was not trying to say no need for pictures just about how there are lots of options which is nice
fuel triton 20x8.25 35-12.5-20 mud champs, stock suspension. -201 rear offset
Did you use the Fuel D500 blank wheels with the +115 offset for the inners? If so, how much clearance do you have between the wheel and the suspension? I am assuming no spacers were used? Thanks.
Yes I used the fuel inners, no spacers there is about 3/4" between the tire and leaf in the rear.
Picked up a new set of shoes for the dually, got tired of the fuels and fell in love with this set, they are made by a small company customforged they do one off sets of custom machined forged dually wheels. This set is 22x8.25, I'm running 35x12.5r22 radar renegade at5 tires. So far I love the setup. 20230830_135124.jpg20230830_135142.jpg20230830_135148.jpg20230830_135157.jpg20230830_135117.jpg
Here’s mine with fuel blitz 20” on 37” STT pros. 2.5” leveling kit with 1” bag and 1” leaf spring blocks since I have auto bags.
Killer looking truck! Ive got the exact same on order and should be getting it in 2-3- weeks! What offset on the fronts? Looking to do the same and get rid of the dually adapters.
If I remember right they’re -19, but not positive
I know I am going to sound like a broken record but 37’s really transform the look of these trucks…. Nice looking truck!
All 8 lug bolt Patterns are the same. Generally come on 3/4 ton and up trucks
No not right at all…. Since 99 ford has been 8x200 when most others were 8x165 now Ram has changed the 3500DRW to 8x200 while the SRW are 8x165. And typically only 3/4 and 1 tons are 8 bolt anything bigger is 10 bolt
I know I have posted a couple times but just made a slight change again hopefully it's my last! I picked up some new front wheels, I wasnt completely happy with the front offsets on the custom forged wheels after adding my 5500 flares they were really tucked, I added some 2" spacers which helped but I was not crazy about running spacers in the front. so I talked with the manufacturer and they offered me some 22x9" flat face dually wheels. They give the front wheel a bit of a lip and adds some offset. More like a super single. I love the look. Plus I now have a full size matching spare that I can run in any location from my old front rim.20250402_111755.jpg20250402_111759.jpg20250402_111807.jpg20250402_111818.jpg20250402_111823.jpg20250402_111828.jpg20250402_111833.jpg20250402_111840.jpg20250402_111848.jpg
