Just swapped out the factory bulbs for LED bulbs in my quad headlights on my '22 Tradesman. I went with a quality bulb around $100/set. The bulbs are super bright and have a great beam pattern but..... there's always a but. With the low beams aimed properly the high beams are up to high. I've adjusted the high beams down to an acceptable level but now my lows are too close to the truck and don't project out enough.
It seems these bulbs are the opposite of light scatter and are highly focused as the beams don't overlap. Has anyone else run into this? Should I swap out the high beams for something else? HIDs maybe? The lows have a built in beam "reflector" inside the housing so I'm thinking I'm limited with options on those. Frustrated to say the least as the stock bulbs really blow and I spent decent money on bulbs and didn't just order some $20/pair off of Amazon.
