QCHunter
I just installed the OEM mid LEDs and used AlfaOBD to change the settings. Just curious what changing the settings does? I tested the lights as I installed and they worked just fine before any changes.
After the changes to the settings I did toggle the daytime runnings lights on the rodeo and the LED strips never turned off. Is this what I should expect or did I do something wrong while changing settings? On AlfaOBD, the screen said to cycle key for 30 seconds. What does this mean when you have a key fob?
Thanks for the help.
