LED Front Turn Signal Bulbs for LED Reflector Headlamps?
el_barto
Does anyone have LED bulbs they recommend for the front headlamp turn signals in the LED reflector housings? Hoping ones to find ones that are 100% plug and play, don’t need resistors, won’t throw bulb-out codes, wont hyper-flash, etc.
Nice yeah that looks like what I’m looking for (not switchback, but looks like they have regular Amber too). Looks like the halogen headlamps and led reflector headlamps probably use the same turn signal bulbs. The LED projector headlamps have LED turn signals so they need not apply.
kind of spendy though...
I ended up ordering them and got them installed this afternoon.
Installation sucked.... the outer bulbs are easy if your arm fits thru the hole in the wheel well liner; but the inner bulbs are brutal. My forearms are scratched up like crazy. On the driver side my Switch-Pros module is right behind the headlight which didn’t help, but it still would have been difficult without that there I think. The passenger side I ended up having to remove the whole intake airbox, which was more difficult than anticipated.
The LED bulbs polarity matters, and you can’t tell until you install it and it works or it doesn’t. Make sure you test the bulbs before putting the airbox or access covers back on.
The bulbs are a bit brighter than stock, and now the front turn signals have a nice crispy “on-off” like every other light on the truck. The headlights still have a bit of “egg yolk” look, but less so than the stock bulbs.
The guy in the video did it in like ten seconds. Haha
