LED Brake light assembly.
mlf15
Good Evening
I recently purchased a 2019 Ram 2500 Laramie. All lights on this truck are LED. My right rear brake light DOES NOT work. All other lights work in that assembly. I’m confused how each of the other lights work except the brake light. It’s a single plug into the assembly from the harness. I’ve replaced the plug that goes to the assembly from the harness as well as installed new brake assembly and nothing has fixed the issue. I’ve checked fuses. But I didn’t see anything labeled that would indicate which fuse it might be. Does anyone have any suggestions? Thanks in advance.
Good Evening
I recently purchased a 2019 Ram 2500 Laramie. All lights on this truck are LED. My right rear brake light DOES NOT work. All other lights work in that assembly. I’m confused how everyone of the lights work except the brake light. It’s a single plug into the assembly. I’ve replaced the plug go to the assembly as well as a new assembly and nothing has fixed the issue. Does anyone have any suggestions? Thanks in advance.
Do you have power to the brake light pin on the plug?
Good question. I haven’t checked that. If that is the issue though then it would have to come from the main harnesses. There is a pig tail that branches off to my assembly which is one of the things I have replaced. I’ll look in to that though. Thanks.
It is a quick way to tell you if the light is at fault or you have to start digging
