NHOverland
So I discovered a mysterious fluid under the steering colum on my 2020 2500 Laramie. I have only used water based cleaners and honestly haven't cleaned the interior since spring... so I can rule out something I sprayed.
We are now at this stage of the investigation.
So far the source has not been located. The drips on the lower column cover suggest that it's coming from inside or through the multi function module. BUT, there is not fluid I can see on the module. Without pulling the steering wheel and taking the whole column apart, which I will not be doing right now, I can not find the issue. I am going to clean the plastic parts and see if it happenes again. If it does, then yes, I will pull it all apart.
If anyone has seen this before or knows the cause, let me know please.
