Largest tire size on 18" rim
asalowe3
I have a 2019 Ram 2500 Big Horn that came stock with 275/70R18 tires. The truck is stock and does not have a leveling kit or any aftermarket suspension. I'm looking to go to an AT tire and wondering if I can fit a 295/70R18. Any thoughts?
Also following. Looking to go from the 3640# rating on the stock 275/70 18s to the 4080# rating on the same tire in 295/70 18. If folks aren't having luck with those, I'm also looking at going to 19.5" wheel & tire combo for the rears.
I have a 2020 2500 no lift and no level mine came with 285/60/20, I just put on 295/65/20 they are about 34.5 tall. No rubbing lock to lock forward and reverse.
I'm back and forth about tire size. This is the closest thing I've found to a straight answer. Screenshot_20200825-195959_Chrome.jpg
I have 295/65/18 on +18 rims and have no issues.
Yeah 18x9.5 with +12 offset. Tires workout to being 34.6 tall by 12.9 wide. So stoked about them. They look great. They are no louder than the stock tires they replaced, quite a bit better ride. I’m running them at 50 PSI all around, but will pump the rears up to 60 when towing.
I have a
I have a stock20211127_155602.jpg 2019 Laramie 3500 and I fitted 295/70R18 Bridgestone DUELER A/T REVO 3 on my stock rims and have had no problems with them. It makes the speedometer 1 mph slower at 60 mph.
