kaodtech security bypass cable not available for 2021 3500 HO
ckdrumm
I am looking for the security bypass cable to use with aplhaodb software. The kaodtech version is out of stock. Saw This Cable on ebay . Has anyone tried it or should I just wait for the kaodtech to be available. Any feedback is appreciated.
aren't they always showing out of stock..? send an email, I believe you can still get one.
I used this one, it works perfectly well but is a pain to install as you need to plug it directly into the security module, which on my 2019 2500 is right up behind the instrument cluster and requires the removal of the cluster to get to it.
If you can wait I'd recommend the Kaodtech cable as it is the same price and far simpler to install
Sent from my SM-N9600 using Tapatalk
Thanks all. I contacted kaodtech, hopefully I get a positive response. Gonna wait and see
Also for 1500 trucks.
The 1500 SGM is accessible at the knee bolster.
The HD AGM is up behind the EVIC (dash cluster).
The KOAdTECH cable plugs into the CAN bus blocks behind the headlight switch.
The two are completely different cables. You don't leave these plugged in when taking it in for service, so it's not an easy thing to rip out the EVIC every time.
Why recommend something you don't know anything about?
Apologies
Don't buy an Infotainment 1500 SGM bypass.
You have to pull the EVIC out to install it. Major PITA.
I have one of these from a prior install. Does it work in-lieu of the Koadtech? KoadTech is sold out, and emailed. No luck!
Koadtech Did not have a cable for my 22 2500. I emailed them also and got no reply back. I sent a PM to Jimmy07 he made 1 and I received it in a few days. It a well made part.
