Is anyone getting random alarms on thier 2019 3500 Cummins SO SRW?
Gray Ghost
For no reason I can figure out, my truck (2019 3500 Laramie Longhorn SO Cummins SRW) "beeps" at me three times. I can be moving 5 MPH or 75 MPH. No messages show up, no red indicators. It just beeps. Driver assist cruise is not on when it does this. I think I caught some red lights flashing on the instrument panel today but I was going down the highway so all I got was a glance. When I go to the messages page on my panel there is nothing there.
Is anyone else experiencing this?
Thanks
Wouldn't that be collision or lane departure warning?
The warning is turned off and it does it sometimes when nothing is in front of me.
Maybe get an OBD2 Bluetooth dongle? You will know quickly if any code are stored.
But as you don't get messages on the display I feel like they might be non-error beeps, related to some security feature of the truck.
I've had this happen at random times too, but not for awhile. I'm sure it cannot be replicated if you brought it into the dealer! :mad:
@Gray Ghost - Mine did it as well and I thought I had the Forward Collision Warning disabled, but apparently not. I had to go in to the EVIC and enable, then disable it. I turned the truck off and restarted it and I haven't heard it since. I believe what you're seeing flash at you on the EVIC is "BRAKE" in red. The indicator is very quick, so it's easy to miss or just catch a glimpse of it. But...I could be totally wrong.
Thanks, I will try to go in, turn it on and turn it off again.
Over a month ago, I was backing up in a parking lot and some idiot in a small car drove behind me. It set off rear parking sensor. It stayed on and wouldn't turn off even after I turned it off manually via the button. I pulled over, shut the truck off, started back up and the alarm continued. I was close to home, so when I got home, I disconnected the battery, re-connected and that did the trick. Shouldn't have to do that on a truck with an 81k MSRP.
Did you loose all of your settings?
