Inverter brand and install
Rgpracer
Afternoon gentlemen, I want to install an inverter in my 2020 2500 and put an outlet in my bed.....first, is it feasible, if so, where is a good location for the inverter, how hard to run the wires and what brand have you used?
Thanks
Some high end trims come from factory with this option and also there is an option with RAM boxes to have a receptacle inside.
I have plug ins inside the cab so in a pinch I could run a cable from there if I needed, but those are only 400W.
If I were installing a power inverter, I would rig it in under the hood just because you need to use very thick gauge wire to run to the inverter and you don't want to run that gauge wire to the tailgate of your truck ($$$).
