Interior fuse box location.
MEGA HO
Alberta
I'm about to install my dash cam that needs to be wired in, not 12V plug in. I couldn't see the interior fuse box in any of the usual places. Anyone get an answer?
There is no under dash fuse box on my 2020 3500.
I hard wired my Dashcam into the mirror wiring. If yours is 5dcv powered you need a reducer in line.
No, mine is 12v. 3 wires: ground, +12 and +12 accessories.
I've got to find something under dash, there's just too little room to work and try to stuff all that wire and power module under the headliner if I were to wire it into the mirror harness like you did.
Sent from my ONEPLUS A5010 using Tapatalk
I understand. Especially if you want to utilize the accessories. Do you have auxiliary switches? If so you have access to switch #6 under the dash. I haven't looked for any 12v leads under the dash. In my other Ram I used the cigar lighter power. In these new Ram with the cigar lighter on top of the dash (bad change IMO) I'm not sure that would be a good choice access wise.
FYI - mine is also 12v and I used this to hardwire, nothing to stuff under the headliner.
https://www.ebay.com/itm/Radar-Detector-Mirror-Tap-Wire-For-Uniden-R-Escort-Beltronics-Valentine-One/143380402205?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
If you have the Aux switches, there are a few threads here about how to easily get an Aux switch, IGN+ and BAT+ into the cab.
Look for the dash camera thread.
No aux switches, wish I ordered with them but it slipped my mind at the time. Will try to look for a dash cam thread. Thx
What I did was get an ac to dc converter and plugged it into the rear power socket. It sits under the rear seats and charges a cellink battery pack which then feeds power to my dash cam.
