Is there a good inspection procedure for the front trackbar. I have front-end shake and tire cupping on my 2020 PW with 67k miles. Bar feels tight but not sure if there is a better method to check.
I pulled the shocks and both are still charged enough I needed a floor jack to get them bolted back up.
Upper ball joints have a very slight radial movement but I would assume I would see inner cupping/wear not outer.
I set the toe to a little on the toe out side. If my math is correct, it is somewhere around .02 degrees.
Truck goes in this week to the shop for an inspection and alignment to Thuren specs but I'd rather tackle the trackbar before it goes in.
