Info? Glovebox Light, under hood light & courtesy light to my 2021 tradesman 2500 CD
ZFORCE
Search engine is no help! I can’t find any info on adding the Glovebox Light, under hood light & courtesy light to my 2021 tradesman 2500 CD. I know previous years had the wiring but I think that was eliminated in 2019+ Rams. Does anyone have a link for any of the wiring or can you direct me to which OEM connectors and pins I might need to add any of them? Thanks
The under hood wiring was gone on my 2018. Not sure what the last year if it was. You’ll have to go full aftermarket if you want an under hood light.
Thanks for the reply. Does anyone know if any of the under hood wiring is worth finding or should I just make my own harness? Since the factory under hood lighting had its own switch, it’s pretty much a stand alone harness. Did it share a fuse with any other circuit?
I finally found a thread on this topic “Adding footwell lighting” and No wiring unless the truck came with the courtesy/footwell lighting, according to @JimmyZ and he knows his stuff!
