AZ Stephen
Hello, I have a 2021 Ram 3500 Cummings and had an idle issue at high altitude. After driving for 2hrs, we arrived our destination at 9300'. I turned the vehicle off to check in. I started the vehicle and the RPM's decreased to 200-300 and then went up to normal. Then the RPM's went back down and back up. I turned off the vehicle to not damage anything. There was no dash light or code thrown. I check to see if there was a blockage in the air filter and there was not. I started the truck again and it did the same thing. I then hit the throttle to about 1000 RPM's and there were no issues. I let off the throttle and it did the same thing. So, I throttled up, put it in D and relocated to our spot while operating the throttle / brake at the same time. I got the truck situated and turned it off. We then checked the fuel filter (which was just changed approx 1000mi ago) and it was not collapsed. I disconnected the battery for 30mins or so thinking something might reset. That was not it. Again, it would run fine at higher RPM but not at idle. I had the truck towed down to the dealer (approx 3000' ASL), left the camper with the camp host, and we rode home with our friends. The dealer then got in it and it ran fine. They did some testing on it and could not get it to duplicate or find any code thrown. So, I picked it up and ran back up the hill to get the camper. As I approached the elevation where the camper was, I put the truck in P. I hiccupped a couple of times. I stepped on the throttle to raise the RPM's and it ran fine. I then let off the throttle and it hiccupped again but it then caught up to itself and idled there. I loaded the camper in 10mins and got out of there. Has anyone had this issue or know what might be causing it? The dealer has no idea. I fear that we go to high altitude again and it will just do it again. TIA
