ThreeBearsHD
I'm picking up my brand new 2024 Ram 2500 4x4 crewcab with the 6' bed and 6.7L Cummins tomorrow. I love building vehicles for my needs, and the Ram is replacing a 2021 Tundra that just wasn't beefy/big enough to accommodate all of my gear and toys while overlanding in Idaho.
Anyway, I want to keep the new truck as stock as possible while equipping it for tackling the mountains. I know the tires I want to run; 255/85R17 Mickey Thompson Baja Boss ATs. These are a 35" tall tire with a narrow 10.5"tread width. I also know the rims I want to run; retro plain Jane OEM steel wheels in a 17x8" size with zero offset.
US Wheels makes such a rim with the 8×165.1 mm bolt pattern.
I will likely add a 2.5" leveling kit to the front in the future, but am pretty sure the narrow 35s will fit with no lift, even with a zero offset. I know a plus offset of at least 15 is preferred for the 12.5" wide tires, but think the setup I am planning will work.
I've done a bunch of searching and can't find any other Ram with the set-up I'm planning. Has anyone else seen a similar set-up? Anyone else tried running the narrow tires?
