How to remove battery 2020 6.4 2500
bubbajim
Can anyone tell how difficult it is to remove the battery? Fender brace above battery looks it has to be removed, also positive side connection has some sort of big module running alongside the battery. I also can't see what holds the battery in until everything else is disconnected. Thanks
simple. remove the brace takes like a minute at most. there is a 10mm bolt holding down a plastic wedge on the engine side of the battery, loosen the bolt and the battery will lift out..
