How to know if in Active Regen - Digital Cluster
scdo
I have a 2023 Limited with the new fully digital cluster. Even with the DPF filter gauge visible, I see no explicit indication of when it is in regen.
Anyone know of a way on this new cluster?
If it’s similar to the earlier ones a message will pop up. Usually around a 24hr engine hour interval. Usually only lasts about 10-20 miles. What do you have for run time?
I’ve had the “frequent regens” check engine code come up so I know it has happened. I’ve never seen a popup though.
I have about 8000 miles and have not had a Regen yet, but have gone through 15 gallons of def fluid is this normal. Gauge on truck 0% on dpf . It’s a 2022 3500 tradesman with the ho
Unless you average over 333 mph then you have had regens, probably 7-10 of them. They occur every 24 hours of run time, at the most, even if the gauge reads 0%.
DEF and regen are 2 different functions that don’t work together. 15 gallons in 8K miles is about 500mpg DEF, which is what I get when I’m not towing so that sounds normal.
