how to access dealer mode
iliv2ryd1
how to access dealer mode on a 2022 RAM 2500 LARAMIE uconnect 5 12 inch screen
This is what the Uconnect site is saying
To ensure we provide you with the correct map update, you will need to get your system’s unique Application Version:
STEP 1:Put the system into ‘Dealer Mode’:
Those are instructions for a pre-2022 Uconnect 4 radio.
That map update is not applicable for your 2022 Uconnect 5 radio.
You can find your software build version in the vehicle settings at the bottom of the list.
I believe that is the most current version that is available.
Also, that is the UC version. Not the map version. So if you’re looking to update your maps you would need to check the version of them as well.
That’s not current. Go to that website and download to a USB. You can update yourself.
Do I understand correctly, the Stellantis method is only for ver5? Is it as simple to update the maps on 4.5?
