I don’t know for sure as I programmed it using the handheld remote as outlined in the manual. I have programmed other vehicles without the handheld remote first step - very much as the manual says for rolling codes after step one with the handheld remote.Does anyone know if your still able to program Homelink if you don't have the garage door remote? We can't find ours.
Great! Thanks I'll try it!I don’t know for sure as I programmed it using the handheld remote as outlined in the manual. I have programmed other vehicles without the handheld remote first step - very much as the manual says for rolling codes after step one with the handheld remote.
Can you try doing just the second 3-step process (attached pic) from the manual? Worst case of it doesn’t work you can clear everything and try for a plan C…. Good luck!
Any luck? Just curious…Great! Thanks I'll try it!![]()
Haven't tried it yet!Any luck? Just curious…
Did you do it without using an existing remote from your garage door??I was successful with the learn button as outlined above?
That is so good to know. Now we've just got to try it. Thanks.I did not have a remote.
