Samsam
My dealership preformed the recall to change out the High-pressure Fuel Pump CP4 and install the CP3 on my 2019 Ram 2500 6.7 Cummins with 130K on it. This was a task from all indications. I do have a problem I believe. I'm not sure. I didn't own it long enough before they did the change out to know if this is their issue. Anyway, I'm getting an idle "chatter" when I first start the truck. It only lasts about 10 minutes after a cold start. I live in a warm climate so cold is like 55F degrees, fyi. The truck smooths out after about 10 minutes and the chatter stops. The overall idle isn't rough other than a slight kind of lifter tick at startup which ends quickly. Anyone else have this issue after the recall on the high-pressure fuel pump?
