Help needed to restore settings changed by AlfaOBD
jpaeth
SO I enabled the settings for TTPMS.. and now i dont even see the trailer brake menu in settings.. Also the color scheme on my uconnect display seems different. red accents now. I dont know if im psyching myself out but Im freaking out thinking i hosed my truck. It still runs.. but I dont know where to go from here
OK, so after driving, I messed the truck up. My backup cam doesnt work, my climate control is stuck on LO but still blowing heat, my passenger side seat heat/cooling controls are missing.
Can I do a restore using AlfaOBD? I took the snapshot before i started...
Post up a link to you current bcm system ID on google drive, and I’ll take a look as soon as I can.
VehConfig 8 - Trailer TPM present - Yes
P/T Chassis Net - TTPM Trailer Tire Pressure Monitoring - Enabled
Sir, I need some help too. I have changed a vehicle config and now I’ve got all kinds of service code and no gas gauge. Hooked up a snap-on reader and it’s saying vehicle mismatch on the snap-on screen. I need to change it all back to factory. All I wanted to do was change the startup screen and add climate to my display screen.
I’m in panic mode here.
I'm in the same boat. I changed my tire size and adjusted tire pressure threshold and now every single light is on the dash and my speedometer or fuel mileage dials aren't working at all. I'm mentally exhausted by this dang OBD sensor. I just wanted to take off the tpms light and adjust my speedometer.
Did you complete the reset procedures after you made the changes to clear all the fault codes?
It's in several post and on youtube videos.
Yours is a different issue.
You just need to follow the steps to do the ABS INIT procedures.
I did but it wasn't working at first. It had some of the options grayed out so I assumed it wasn't going to work. I continued on with the steps and some of them worked and at the end I turned truck off and back on and it cleared all lights except check engine light. My speedometer is back working and mostly back to normal thankfully. GPS shows speedometer spot on with the tire change input I used.
Occasionally, I've had issues with AlfaOBD not resetting the MIL. Make sure you go into the ECU and do a check and clear fault codes.
Optionally, fire up the OBDLink app (if you have there reader) or use Torque to clear codes.
Hello so I have an issue with my 2022 Ram 1500 Limited (with air ride). Last night I changed 2 settings and my vehicle is now stuck in what appears to be Entry/Exit Mode while indicating that it is in Off-road 2 Mode. [see IMAGE #2]
[IMAGE #2]
[IMAGE #3]
1.) First off I used the “Write Suspension Height Values” in the “Suspension” portion of the app in an attempt to raise the left side of the vehicle about 11mm to level it with the right side of the vehicle. Before changing anything, the factory “Calibrated Heights” values were 0/0/0/0 [see IMAGE #3]. The factory values of 53.33/56.71/48.99/49.23 for the “Ride Height Sensors” were similar to the factory “Calibrated Heights” the Ram Rebel had in the video (
) I watched about adjusting this value. I initially added 11MM to what the FL and RL “Ride Height Sensors” values were and used those values (64/56/59/49) to Write the Suspension Height Values [See IMAGE #4]. After realizing the drastic difference in the factory values and the values I entered I almost instantly returned it back to 0/0/0/0. I hope this means that this setting is back to normal now. The “Calibrated Heights” currently show 0/0/0/0 again, but I notice that my “Ride Height Sensor” heights are all a few MM different from what they were originally in [IMAGE #3]. Shouldn’t those values be exactly the same as what they were before I changed anything now that my “Calibrated Heights” are back to 0/0/0/0?
[IMAGE #4]
2.) Secondly, in the same sitting, I used the “Set Ride Height Level” setting in the “Suspension” portion of the app just to see what it would do (terrible idea!) and ever since doing that I’ve tried adjusting the setting every which way and I can’t get it to function as it should. It seems as if it is stuck in Entry/Exit Mode while the vehicle indicates it is in Off-road 2 Mode so it won’t let me adjust the suspension neither up nor down with the button on the dash.
I just put 35”X12.5” tires on the thing last week so it is completely undrivable the way it sits. If anyone knows how to get these settings back to normal and/or has any tips or pointers I want to hear ‘em! Thanks in advance
