Gotta question about a rear axle
35hundomegacab
Does anyone know if a rear axle is compatible in a 2013 ram 2500 with a 3.42 gear ratio with the leaf spring suspension and is 4x4
And a 2016 ram 3500 megacab non dually 4x4 with a leaf spring suspension as well and the 3.42 gear ratio and also 4x4...
My 3500 axle is a Lil bent I think and im having trouble.finding a used 1
If both are leaf sprung trucks they should bolt up, the only possible issues would be the pinion flange style and ABS sensor locations
Thanks a lot for the response i appreciate it bud... Just didn't want to go and buy this and it not line up cuz theres no refund if its wrong
The 3500 would have been helical limited slip. The 2500, probably not. Optional vs standard.
If you aren't planning on swapping internals...
