Fuse Help 2021 Ram 2500 6.4
Whitwymin
Not sure if this posted correct place. But my wiper washer fluid is not coming out. Can someone guide me to where the fuse for this is so I can check it?
Also my overhead center console lights that come on when doors open are not coming on. Either side. Is there a fuse for this and if so where would it be? I looked through owners manual and it doesn’t list them specifically.
I looked page 434 I believe or in 400’s. I went through alol the pages of fuse listed and I did not see them listed unless they are listed under some cluster but It does not say. That’s why I post to see if anyone knew. Thanks
Try pressing the ww fluid button on the stalk with the ignition on but the engine off. See if the pump is making noise that way you know if there’s a clog before going too crazy on electrical diagnosis.
As far as the overhead lights make sure the setting on the dash by the headlight switch didn’t get inadvertently switched to the off position.
