fuel rail pressure low
jeffn
I was driving to work this am and taking off at a light the truck started lurching and cutting out. I pulled over, the truck did not stall and idles fine. I proceeded knowing there is a Ram dealership 6 miles ahead. The truck could drive with limited throttle, basically above idle, but when I gave it throttle it started cutting out and definitely had reduced power. Made it to the dealer, the datalogger says the fuel rail pressure is low.
It is there now, do you have any thoughts?
2020 3500 DRW
HO
60,002 miles… powertrain warranty is 60k
fuel pump recall has been performed
What was the ambient temp?
How old are the fuel filters?
not in the six miles I drove from first experiencing the problem to dropping it off at a dealer service center.
Fuel filters can be clogged and still read 40%, that reading is just a algorithm Ram has set in the computer.
2020 3500 DRW
HO
PS cummins engine warranty is 5yr/100k if it’s something related.
Fleece, fass, airdog, always been less reliable than stock. Ok except maybe the early 2nd gen 24v when the LP was mounted to the engine...
I'm amazed how many of those things I see fail (and almost never a stock one) yet people keep pushing them as a "must have" upgrade.
Update.
My Fleece lift pump failed. Zero PSI from the pump to the chassis filter.
Why did you change out the OEM pump?
Exactly my thoughts…. Even with my 01 VP truck i still run both style (block side and in tank) OEM pumps together and have less issues than i did with the FASS i had on a different truck
