fuel filter drain
william
what size is the hose coming off the fuel filter?
I tried looking but probably didn't type it right.
Are there any improved designs for the chassis mounted fuel filter/water seperator cap? I opened the drain, drained housing, closed drain removed and replaced filter....once completed hosed everything down and primed, only to find the drain oring failed and leaked fuel all over the floor.
It's a little tricky. O ring needs to be seated in a notch. I needed to use my reading specs to see it.
I designed this little tool, and it works perfectly! Not a single drop on me or the ground!
I bought a billet aluminum cap for the front filter much easier to remove in my opinion . Once you get your filter back together and go thru the priming stage check your filter housing for leaks prior to starting . Much less mess . Found out the hard way once .
