Front Park Sensors Alarming When Backing With Trailer Hooked Up
steve49
Show Low, AZ
When backing up my toy hauler with the seven-pin plug plugged in, my front park sensors will occasionally beep and display in the EVIC, however there are no obstacles in the way to set them off. I remember reading others in another topic thread have experienced this as well, has anyone found a fix for it?
Are you sure its the fronts? My rears would do it (i dont have the fronts) after a dealer update at one point it stopped doing it
Yeah, it's the fronts and because of the weight distribution hitch, I have to have the rear sensor turned off or I'll get a constant beep! Not a big deal and as I said it's just occasionally that it does it.
Same here. Since I got it.
Yes but even with the rears off i would get an occasional odd beep or 2
Can't for the life of me find that full TSB but start with Star case
S2019000002 Hands On Steering Wheel Message In EVIC​
This and many others were all rolled up into a larger flash TSB. I'm not 100% certain it's the one in this post.
