I have a 2021 PW with an 8.5-inch screen. I don't have a 360-degree camera. I wanted to add a front camera and a 12-in screen so I bought the products below and wanted to share with the forum in case you want either/both. I added links to both sites and YouTube install videos as well.
Universal Front Camera Kit for Factory Display, Fits 2019-2022 RAM®
URL: 2019-2021 Dodge RAM® Front Camera Kit for Factory Display - Camera Source Backup Cameras
Can't see over that hood? This is your solution and is a Camera Source exclusive for any 2019-2022 RAM® 1500,2500,3500 series with UAV 8.4" or UAX 12.1" factory display!!
This universal camera can be converted to mount on any flat surface so you can place it and adjust to obtain an optimum view! The camera has adjustable tilt and comes with parking guideline options, meaning that the guidelines can be turned off. The included screen interface provides multi-cam support so you can add up to 4 cameras to your factory UAV 8.4" or UAX 12.1" display screen!
The integration module allows for plug and play integration into your factory screen without having to flash a program your radio. The factory rear camera will come on automatically when in reverse and front camera can be manually activated using the included activation button.
Kit includes:
2019-2022 RAM Heavy Duty UAX Uconnect 4C NAV 12" w/CarPlay & Android Auto Upgrade - RAM HD Power Wagon | VEHICLE VIN: 3c6tr5ej7mg645156 | Keep Manual A/C: $0.00 (#C-BDLUAXHD-X8)
URL: 2019-2022 RAM Heavy Duty UAX Uconnect 4C NAV with 12-inch Touchscreen including Apple CarPlay / Android Auto Upgrade - Infotainment %
Our reconditioned factory upgrades feature a 90-day guarantee and a hassle-free return policy. Extended warranties are also available!
100% Factory RAM® Embedded 3D GPS Navigation including Apple CarPlay® & Android Auto®
Supports English, French, & Spanish languages
No-hassle, Plug & Play system. Pre-programmed to your specific vehicle. Eligible for our Compatibility Guarantee.
Installation
The installation of this product would be rated a 2 out of 5. 1 being extremely easy and 5 being extremely difficult. It is recommended prior to installing any automotive electronics that the negative battery terminal be disconnected.
URL: OEM 2019-2020 RAM Truck UAX Uconnect 12-inch Touchscreen w Apple CarPlay & Android Auto Upgrade - YouTube
Product Features
Kit includes:
- CMOS license plate mounted camera- with dual mounting bracket
- Screen interface module for your factory radio (radio not included). Provides multi-camera support for up to 4 cameras in addition to your factory tailgate camera.
- Mounting hardware
- Camera wiring harness
- 12V power module
- Zip ties
- Detailed installation instructions
- 3-year limited warranty
- Mini license bar universal mount camera with dual mounting bracket
- Super CMOS sensor for ultra clear display
- Resolution: 600 TV lines
- Minimum Illumination: 0.2 Lux
- View Angle: 170
- Video Output: Full color video
- Working Voltage: DC 9-16V
- Parking Line: On/Off selectable
- Image: Mirror/Non mirror selectable
- Waterproof: IP67
- 25 foot harness
- Uses existing UAV 8.4" or UAX 12.1 factory display (screen not included)
- Allows addition of this front camera that can be manually triggered using the included activation button
- Pass through for existing factory backup camera
- RCA inputs for 4 additional cameras
Installation
Product Features
- 12-inch High Resolution Touchscreen Display with Split-Screen Capabilities
- Embedded GPS Navigation
- Apple CarPlay ® / Android Auto ® Ready
- AM/FM radio
- HD Radio ®
- SiriusXM ® Satellite Radio with 360L (subscription required)
- SiriusXM ®Traffic Plus & Travel Link (subscription required)
- Integrated Uconnect® Voice Command and Bluetooth® ready
- Automatic Temperature Control – Enables Auto HVAC Control for those who do not have it.
- Speed-adjusted volume
- Pre-programmed to function with your vehicle’s existing steering wheel mounted audio controls. If you would like to add this convenient feature see our Factory OEM Leather Steering Wheel with Audio Controls.
- Pre-programmed to function with SiriusXM satellite radio. If you currently do not have factory installed satellite radio we will include a small antenna adapter U-INTC2K to be plugged into the mustard/curry colored FAKRA port on the UAX module. This will allow for GPS and SiriusXM.
- Pre-programmed to function with your vehicle’s existing digital back-up rear view camera. Also supports the 360 camera system (if equipped).
- Pre-programmed to function with your vehicle’s existing UConnect® bluetooth hands-free calling feature.
- When upgrading to this unit you will not gain Sirius Guardian® or the embedded 4G LTE Hotspot capability as both features require additional hardware and unsupported subscriptions.
- This upgrade is designed for trucks with our without existing automatic climate controls. If you would like to add this convenient feature install our plug & play Auto Climate Control Kit.
- UAX GPS Navigation Radio Module
- Replacement Instrument Panel – Specific to Trim Level
- Replacement High Gloss Radio Bezel with an Award Winning 12-inch Display Screen
- Infotainment Ram Wiring Harness for Display Screen
- LVDS Video Cable
- 4 Nuts / 4 Screws
- OBD Genie Programmer
- Security Gateway Module Bypass
- Compass Antenna Converter Cable (Included if the customer does not have SiriusXM capability)
