I am seeing good deals on 20in wheel and tire combinations and I am wandering what problems I should expect. Speedometer readings? Tire pressure sensors? Rubbing? Ride?
installation? Any help or advice would be appreciated. Thanks
If the overall tire height is the same, no issue there.
However, it could be a harsher ride going from 18 to 20 rims. Less sidewall in the tire to flex and soak up the bumps.
as was stated above if actual height is the same your speedo won't change and ride could be rougher. depending on backspacing/offset you may have rubbing. sensors should transfer over no problem.
