Are they leaking?What's everyone seeing for life/miles on the Fox IFP shocks?
I got about 50k-ish on mine and get weird wiggles every so often and it rides odd.
37s if it matters for tire size.
-Dave
I haven't pulled the boots back to check yet. It's on my to-do list this weekend. But that just checks the exterior seals. If the internal one is gone or the nitrogen leaked, I'm not sure how to check that.Are they leaking?
I appreciate the info!you could have a clapped out shock. A loss of nitrogen could be noticeable especially with the odd suspension characteristics these trucks already have. Shock oil doesn’t really have a life expectancy but it should be changed when the shock is rebuilt. Typically on a life durability cycle the shock loses less than 10% of its dampening over its lifetime due to oil breaking down. Wouldn’t see a drastic change unless it leaks. Shocks can leak oil out or nitrogen out or leak internally and mix. shocks can lose nitrogen through a worn o ring or through a damaged fill port.
If you pull the suspected shock and compress it and it doesn’t push back out, you’ve lost your nitrogen. I’m not sure how to tell from external inspection if you lost an ifp seal and you have aerated oil I’ll try to get back to you on that
I found that page today poking around their website as well. Looks like I'm buying a set and I'll send out the worn ones for a rebuild later on.
Fox manual recommends 50,000 miles for street use. I have yet to see a single HD ram on this forum being used in a manner that would require 10k or even 25k mile shock rebuilds. “Motorsports use” is not occasional slow trail riding. The one Hd Ram I have seen jumping stuff was in a carli advertisement and they were running 3” kings with resis which we aren’t talking about here.Thru the heat cycles of the shocks, your saying they only loose 10%.
But Fox says to rebuild them at 25K I beleive.
Yea, not sure how you can check the IFP to see if it leaks. Other than find a place that can recharge them. Remove the plug where you charge it, release the nitrogen and see if any oil comes out. If not, then have the recharge it. Also have them check the pressure before they release any to see if it's low.
That's about the only way I can think of.
That’s doesn’t surprise me on that type of usage.For some reason, I thought it was 25K.
But we rebuild the Fox race shocks after every race, longest being 1K Mike's.![]()
Might want to check their price on a rebuild.I found that page today poking around their website as well. Looks like I'm buying a set and I'll send out the worn ones for a rebuild later on.
I wanna say it was $90 a corner for the IFP ones. About half the price of new ones.Might want to check their price on a rebuild.
Or find a local shop to rebuild them.
