No the mopar ones have no holes in metal....Which ones? The Rubber style requires one hole to be drilled through metal but only on the fronts.
Then why do the instructions call for rust preventative on the top hole of the front flap installation?No the mopar ones have no holes in metal....
Not a clue but it goes beside the metal not through itThen why do the instructions call for rust preventative on the top hole of the front flap installation?
The rubber ones are the ones i have. And yes it is the fronts that i am questioning.Which ones? The Rubber style requires one hole to be drilled through metal but only on the fronts.
See my picture they are exactly where they are supposed to go the flap is indented where it fits if you dont have flares so it cant be offThe rubber ones are the ones i have. And yes it is the fronts that i am questioning.
From what i can see it does look like the top hole needs to be thru the metal to fit correctly, or look right shall I say.
Just asking, didn't really want to drill through the metal if I don't have to!
