Fog Lights
jak
Western Mass
Recall finally done picking up truck this afternoon, 2022 Ram 2500 Tradesmen. I want to install fog lights, I have lights, brackets and hardware. I will need the wiring harness. Also want to use my factory installed auxiliary switch rather than connect to headlight switch. So I am hoping someone here has done this and can help me out with part #'s and installation tips. Thanks.
Here’s the master thread:
Well I got all the parts, wired everything up and figured I would make sure everthing works before I mounted the lights. These are led lights (that I purchased used). Is there a way to change the bulbs cause they don't work and I cant figure out how to get at them. It almost looks like you would have to purchase the entire housing? Getting voltage at both plugs (oem harness) also plugged in a halogen bulb and it lit right up so I know its wired properly. This is wired into my auxiliary switch. Getting 12.7 volts at the plug.
I think the LED need to be wired opposite of the halogen bulbs. That monster thread may have more info.
  • Like
Reactions: jak
All is well, thanks flan and others. One last question is there a way to adjust the fog lights? There is a single screw on the back, not sure what it does.
It’s been a bit but give that a shot, iirc they are adjustable.
