1FstGPa
I am in the process of of ordering some parts to fab a simple wiring harness for my added fog lights. The plan is to use 14ga wiring, both + and -, to the aux connectors. #3 connector - upper right while looking at it - on the light gray connector shows as a ground. Will I need to run the negative side of the light socket to this connection or can I just ground to frame? My concern is making sure to take advantage of the auxiliary PDC on board relay for this light setup.
And while I have your attention...
Light gray #4 shows as a "Spare Circuit Pass Though." What exactly is that?
Thanks in advance!
Thanks in advance!
