Fog Lights activate by turning wheel
regal2800
At night when i turn the wheel in either direction going into a turn, the fog light on the side of the vehicle im turning will turn on. Is there anyway to turn this feature off? i like how the head light turns with the steering wheel, i just wish i could deactivate the fog light from turning on. Any input would be great.
I had not seen that feature listed. It may be a setting in the uConnect options that can be disabled.
Just turn your fog lights on and leave them on...imo looks nice at night and really lights up the area and doesn't blind anyone.
Howdy,
On some cars it was known as a cornering lamp. It added lighting to the turn signal side to see where you are turning.
Unless your not explaining it enough.
ya its a cornering light. the problem is i took the cornering lights off and replaced them with 4 Rigid LEDs for off road use. every-time i turn a corner it's like someone turned on stadium lights.
If it is like the 1500, there is no way to turn off the 'cornering' function on the fog lights... it also illuminates when you use your turn indicator.
Man says to doctor, "doc it hurts when I hold my arm up over my head. What should I do?" Doc says "Quit doing that."
Hope the new cornering lights don't blow a fuse, difference in draw between them and the originals. You might need a trip to the doctor if the overload the circuit :)
Same. I like the idea of the feature but if a cop is in front of me on a curvy road my BD Squadrons that replaced the stock fogs are going to get me in trouble. I had no idea that I had this feature otherwise I would have considered placing the BDs elsewhere. Any figure out how to turn this feature off?
I was aware of the cornering lamp but did not realize it activated the fog lights. It does provide a noticeable amout of additional light but it looks strange when only one fog light is on. As someone stated above I guess Ill just run the fogs full time.
