Fluids, etc.
PVOLLC
Hi guys, been a while. About to top off power steering and brake fluid on our 4500 cummins. Wanted to check here for any specific recommendations on fluid manufacturers before I did. Also, do you guys use all purpose HD grease for your UV/CV joints or is there a super special grease you use?
Does your 4500 have any grease joints? My oem joints 2500 did not. NLGI 2 is usually a suitable grease if you do have any.
As far as brake and PS fluid just follow up with your owners manual, whatever brand meets the recommended spec will do just fine. Most on the shelf will.
