First time RAM owner needing help with codes.
Crawdaddy1
I recently purchased a 2019 RAM 2500 with the 6.7 Cummings Diesel engine with 122,000 miles on it. The dealership replaced the DPF filter but after I got the truck home it was throwing multiple codes. P0234, P0402, P24B5, P24C9, and P24C7. I've cleaned the EGR valve, and replaced a bad DEF Injector, but I'm still getting the P24B5 and P24C9 codes. The truck runs great otherwise I just wish I could get this remedied and have peace of mind by not having a check engine light on.
Any input would be greatly appreciated.
Thanks,
Crawdaddy1
Check battery voltage on PMS connector pin 1. Check good ground on pin 2. If those are both good, replace the PMS, the module comes with it.
