Fairlead allen wrench size
Crusty old shellback
Need to pull my bumper and that requires taking off the fairlead. Mine is a '21 and has Allen bolts in it, not Torx.
Anyone know for sure what size Allen is needed.
I measure it and get 12.4MM or 31/64.
1/2" is too big.
Thanks
Try a 10mm...I'm thinking they went metric. Harbor Freight is a great place for those "one time" use tools, maybe a two time use
If you plan on responding, please read the entire post I made as all the details are in it.
It's not a Torx and it's bigger than a 10MM, all of which I put in my original post.
it must be a 12mm Allen. There is no other size that makes sense
7/16 is 11.something and 1/2 is 12.7 (too big as you said)
A 3/8" ratchet just spins.
A 1/2" doesn't fit.
Do they make a 12.5MM?
Was thinking of getting a 1/2" and grinding it down to fit.
A 15/32" is a little small, same as the 12MM is a little small.
A 1/2" doesn't fit.
Really odd that it’s a goofy size. That size may exist but I haven’t seen it.
I have a huge Allen kit. I just checked it and there aren’t any half sizes between 12 and 13; half mm sizes stop at 6.5, I believe. Nor are there any 32nd sizes between 7/16 and 1/2.
Thanks.
So I'll get either a 1/2" or 13MM and file to fit
Or get a 12 MM and hope it works.
I'll test fit before I leave the store parking lot. It's a 40 mile drive home from the store. :rolleyes:
Not quite seeing the NOT 10mm part....Sorry to take up your time..
""Need to pull my bumper and that requires taking off the fairlead. Mine is a '21 and has Allen bolts in it, not Torx.
1/2" is too big.""
