Failed Batteries or something else?
jmcdermo
Santa Fe, NM
On our recent trip with our 2019 2500 diesel,towing our trailer, the truck decided not to start. It was on the tail end of a 2-week trip in the Grand Canyon campground around 9am. The temp overnight had been mid 40s and it was about 55 when this happened. It went through the diesel pre-heat sequence and then gave one weak click or clunk, which was normally followed by the sound of the starter turning over, but this morning it made the half heated sound and then it would start the sequence all over again: ding, ding, ding, diesel pre-heat, etc.
Tried a jump box that the rangers had, no joy. AAA arrived and connected the jumpers from the little service truck and it turned right over. So we got on our way driving all day without shutting the truck off. The whole way I was watching the detailed voltage display. The alternator seems to be good - charging at 14.1 or 14.2v for the first part of the drive and then backing off to 13.7 or 13.6v later in the day. I took that as a sign that the batteries were back up to charge. When we got to our destination for the night I shut the engine off and checked the voltage - 12.7. Seemed like the batteries were charged.
The following morning as I started the truck the display showed 11.5v (seems bad), but the truck started and the alternator and batteries repeated the behavior of the previous day with the batteries showing 12.7v after I shut the engine off at home. This morning, it again showed 11.3v in the process of starting the truck and before the alternator kicked in.
I’m thinking failed OEM batteries. The truck is 3.6 yr old with 38.5k miles. So I took it in to an Advance Auto store, planning on getting a pair of DieHard Platinum AGM batteries. But, first I wanted the batteries to be tested. I didn’t want to buy new batteries if the existing batteries tested good. When hooking up their automated tester it threw an error about seeing “noise” in the system and prompting us to be sure everything is off. Everything I had control over *was* off.
So, before I spend $$$$$$$ at our local FCA dealer chasing electrical gremlins I borrowed a friends clamp amp meter. Here’s what I found. With the truck idling it shows almost 5A load. Immediately after shutting the truck off it drops to around 2.5A. 5 min later it’s still slightly over 2A. After 10 min it dropped to around 1.25A. And, at 15 min it dropped to 0.85A. I quit watching after 20 min with it still reading 0.85A.
For comparison I tested our 2018 BMW X3 M40i it showed a steady 1.1A after all the lights went out and the displays went back to dark after just opening the drivers door and popping the hood.
So questions:
1) feels like failed batteries not holding a charge. But I don’t want to spend for new batteries only to have the truck’s electrical system kill them too. Thoughts?
What about the “noise” in the system (load?). I’m sure we didn’t wait 15 min before trying to test the batteries at Advance. So the test equip was probably seeing the 2+A load, whatever it is.
2) After 15 min, still showing 0.85A seems pretty “normal” when compared to our BMW. That shouldn’t stop the test equip, should it?
3) What about disconnecting the Neg from the battery being tested. Since that battery won’t be grounded and the test equip clamps are only connected to the battery posts (not the vehicle ground) it shouldn’t “see” any load, right?
4) has anyone else had a similar experience?
Any thoughts or suggestions will be greatly appreciated.
Cheers!
I've never gotten more than 2 years out of an OEM Mopar battery and now I just plan to change them out to AGM once a vehicle is 18months old to avoid the annoyance of needing a jump ... I also run these guys on everything that gets run often or I keep a maintenance charger on those that don't. Have two on my truck running directly to each battery's terminals.
I know there are other brands with similar technology, but having talked to some of the folks involved with the Pulsetech testing out at Ft Hood for uncle sam and seeing the results on our equipment batteries I'm a believer. Having many of the deep cycles testing like new after 5 years where previously we'd maybe get 2-3 years it's doing something right.
Verdict:
Got the batteries tested at my local Advance Auto. I went there because I wanted the DieHard Platinum AGMs if I needed new batteries. Turns out only one of the batteries was bad. 10v and showing only 30CCA. So I replaced both batteries and I kept the good battery as a 12v power source.
No I just need to figure out how to get all the apps back on the 12” dashboard display.
Sad.
I got 13 years out of my 04.5 OEM batteries.
The batts in my 2020 are junk and will need to be replaced before next winter. Dealer visit will use every excuse in the book re parasitic draw to avoid replacing them.
I got 12 years out of my OEM 1997 batteries.
A friend that used to be an ambulance mechanic got me a hookup on some well priced Deka batteries (East Penn) he swore by. Those ended up being junk too. Got maybe 4 years out of them.
One could say it was from the truck sitting a lot, but that doesn't explain how the OE batteries were able to last that long. I have to imagine the parasitic draw of the new vehicles is greater than what the batteries can tolerate. Mine almost always needs a jump after sitting for 2-3 weeks. Sometimes the crappy jump box is enough. Sometime not. It also won't remote start after sitting a week but will start from the cab
Must be climate change.
I can promise you that the parasitic draw on a 1997 truck is not the same as the draw on my 2019. Hang onto the ‘97!
.050mA is the max allowable for a 97
.085mA is the max allowable for these trucks with way more computers. Its not a huge difference but if people have addons like hardwired dash cam or other things it would easily pass the .085A allowable
Interesting - that’s good to know. In my recent testing I never saw anything lower than 0.5a and that was after 20 min of sitting and all the USB cords unplugged. The only add-on plugged into 12v socket was a radar detector, but the power port on top of the dash is off when the truck is off. I have add-on powered running boards connected to the ODBII port, but with the truck off, I’d expect them to be powered off as well. Of course it could be the quality of my clamp amp meter.
