Factory LEDs
CRToney
Dealer installed Factory LED headlights. No difference in light when I turn on brights going down highway. The high beams are coming on. There’s a dead spot that my halogen fog lights fill in. Do the lights need to be re-aimed?
It sounds like they could be aimed too high causing the high beam light be so high they're not lighting up what they're supposed to.
Do you see the cutoff when you have the low beams on? How high is it? Does it look like it will blind drivers on low? If it does they are aimed high.
I feel like my led hi beams are too hi in elevation but my lows are right on the money. When spring hits maybe ill point it at garage door and drop them a hair..
I’ll have to check out how they are aimed. I’m guessing the technician didn’t aim them upon install.
