Factory LED Taillight error message
jbncccb
So I have a 2019 Laramie with LED taillight and backup sensors. I keep getting the error code that the turn signal is out as well as fast blinking. However, I go look at the light with the signal on and it is blinking just fine, with all LED's lit up. Parking lights work as well. For grins I checked the front signal and the one on the mirror and it works as well. I pulled the lamp assembly and noticed there is some slight condensation in the lens. Do you think this condensation might be causing it to fault to ground? When I pulled the plug it was dry as could be.
Since all the led lights are still working can I just dry out the light and re-seal?
I know I can pull the BSS sensor out but any other disassembly I should do to fully dry it out w/o damaging the lens, etc.
Thanks
If the rear lamp has moisture in it that could be the problem, you can pull the BSS and try to dry it out
