Edge CTS3
oledirteh
Union Bridge MD
I was looking at it for the monitor portion but noticed that they now offer this
With gains as much as 60hp/130ft-lbs torque, the EZX can be adjusted while driving through your factory steering wheel controls, allowing you to fine tune your driving experience at your fingertips. Using the innovative smartphone app available for download through your app store (available for both Android and IOS) you gain even more access to your trucks features including calibrating for tire size and gear ratio changes, throttle pedal sensitivity, max cruise control speed, exhaust brake/tow haul button recall, TPMS settings, engine temperature protection, gear display, fog lights with high beams and even a turbo timer! EZX app also allows you to read and clear trouble codes, check your emissions readiness status and perform a manual DPF regen cycle.
not exactly sure how i feel about it. Looked at the install and looks like your pig tailing off all the existing wiring for fuel rails and what not.
