Do you have any pics of the whole truck? And do those flares just glue on or is there more to it? Any reason they wouldn't work with my Weathertech mud flaps?Most fender flares for a SRW Ram should work. i put OEM Power Wagon flares on my DRW.
There are a couple threads about how to mount latest Gen OEM flares on trucks that did not come with flares. Which has much more detail. Short version. Trucks that come with flares have holes in the fenders. I did NOT drill holes in my truck. When you get the OEM flares they will have the clips mounted on. you will need to modify the clips. real easy. I cut the tab that goes in the hole off then flipped the clip around then used 3M VHB double sided tape on the clip. (tape is optional) the flares mount around the edge with factory screws. I also used Anti-friction tape under the flares just in case the flares flex and protentional scratch the paint. Don't think it was really needed on these flares with the 3M VHB tape though. As for working with mudflaps. Not sure. would need to be ones designed for trucks with flares. even then maybe not because OEM Power Wagon flares are a bit different than standard flares.Do you have any pics of the whole truck? And do those flares just glue on or is there more to it? Any reason they wouldn't work with my Weathertech mud flaps?
Thank you!!! Do you have a rough idea of how much tire coverage they provide? I need 2-1/4" to be completely covered.There are a couple threads about how to mount latest Gen OEM flares on trucks that did not come with flares. Which has much more detail. Short version. Trucks that come with flares have holes in the fenders. I did NOT drill holes in my truck. When you get the OEM flares they will have the clips mounted on. you will need to modify the clips. real easy. I cut the tab that goes in the hole off then flipped the clip around then used 3M VHB double sided tape on the clip. (tape is optional) the flares mount around the edge with factory screws. I also used Anti-friction tape under the flares just in case the flares flex and protentional scratch the paint. Don't think it was really needed on these flares with the 3M VHB tape though. As for working with mudflaps. Not sure. would need to be ones designed for trucks with flares. even then maybe not because OEM Power Wagon flares are a bit different than standard flares.
PyroJoe: you need an additional two and a quarter inches to cover the tires on a dually. Those must be some wide tires. Did you put additional spacers or change the dually hubs? Any pictures you would like to share?Thank you!!! Do you have a rough idea of how much tire coverage they provide? I need 2-1/4" to be completely covered.
Pyro
Those tires look good and I see what you mean about the side lugs. What tires are they?Not really. 255mm wide vs stock 235mm. It's these stupid obnoxious side lugs. They increase the area you need to cover since they'll sling stuff. Front is stock specs. Rear had to get spaced out 1/2" to theoretically maintain 1" of gap between tires. I really hope someone else steps up and makes a 255/85R17 before I need tires again. Otherwise I may step down a size so I can go back to Duratracs.
View attachment 86878View attachment 86879View attachment 86880
Thanks and thanks! They're the Mickey Thompson Baja Boss 255/85R17, the tallest dually-friendly tire, as anything 10.50" wide, 265mm wide, or wider requires 7"+ wide wheels. This 255 has a 50k mile warranty as long as you mount it on the minimum 6.5" wide wheel, which is the widest dually wheel available. The Dodge are 6.0" wide hence why I had to go aftermarket, but I tried to match the factory offsets exactly, other than the rear inners which I tried to increase to move them towards the inside more.Those tires look good and I see what you mean about the side lugs. What tires are they?
Good luck with the fender flares getting that edge under wraps.
