I have a 2018 3500 Longhorn diesel with dual 440A alternators, and dual battery. I want to be able to charge my 12V land based battery backup system which I use for powering freezers, fridges, and house gas furnace etc. System works great as long as there is mains 120VAC. During power failures batteries run the load for 2 to 3 days. Currently the batteries charge via AC through a Magnum inverter/charger. For extended power failures the plan is to use a gas generator(120VAC) every few days to charge the batteries through the Magnum. When I run out of gas or can't get any, the RAM could be a great backup.
Getting to the point.... with all that capability in the RAM, I should be able to charge these deep cycle backup batteries, total 832 Amp hours, fairly quickly.
Questions: Point of connection in the truck, does this(photos) look like it would work? Any better suggestions? Ideas? Because the connection is temporary, could I use a booster cable clamp on the top of the battery pos terminal? Thanks!!
