DRW Inner Tire Extensions?
TXsportDiver
On the inner rear wheels of a dually, RAM includes a plastic valve extension, to make it easier to check tire pressure/inflate. However, I can't seem to get a good seal on the factory extensions. Any recommendations on better valve extensions?
After dropping the first couple of outer rear tire valve caps inside the wheels, I have been using Haltec DS1 caps on the front and outer rear tires...they work very well...despite the lack of caps (which could be added). https://www.haltec.com/pc/Double-Seal-Valve-Cap-194p1039.htm
Has anyone used the Haltec extensions with OEM wheels? If so, what length?
The Central Florida mobile tire shop that was servicing tires on the RV across from me gave me two of these. Referred to them as "Gator Caps".
