Driveline vibration
raz
Hello all I have a 2500 4x4 .
I have a vibration between 45-60 mph if a trailer is attached the tongue jumps up and down. I have been back to the dealership 3 times . They rotated and balanced the tires every time I was there . It seems like a driveshaft issue or u- joint I was wondering if anyone had the same problem. The truck has 11,000 miles
Thanks
If the tongue is bouncing the trailer is not balanced properly, could be an unbalanced drive line an easy test if pull the front shaft and go for a drive if its good then you know the issue if its not better throw the front shaft in and remove the rear shaft and take a drive in 4wd see if the issue persists
It's definitely the rear of the truck .it's any trailer
