The owner's manual for our 2022 3500 DRW says the following:
NOTE:
If your vehicle is equipped with an air suspension system, there is a feature which allows the automatic leveling to be disabled to assist with changing a tire.
Assuming you are jacking under the axle as recommended, can someone tell me how disabling the automatic leveling will make any difference.
I can understand this if you are lifting under the frame and suspending the wheels. Putting a jack under the axle is no different than driving onto a bump in the road.
NOTE:
