Dimmer Switch Flicker Issues?
BigOlMega
I have the dimmer on MAX so I can actually see the display at night with the headlights on, however, it stated to random flicker from bright to dim all by itself. Took it in to the dealer and they replaced the switch. It stopped for a couple months but is not doing it again. Looking online, I see that the switch has SEVERAL revisions........... Ordered one ($28) to compare to mine and see what revision I have.
Anyone else see a random flicker on the max setting?
Or also check all your fuses to see if they are fully seated. This was brought up in another thread, I found 40% of mine not fully seated.
Sorry to hear of the trouble you are experiencing, BigOlMega. If you are not able to determine a solution with the suggestions provided here, we kindly recommend following up with your servicing dealer on this. If you do engage your dealer again, we are more than happy to support you through that process.
Mark
RamCares
