I’m trying to find a wheel that doesn’t stick out. I have a 2021 ram 2500. I’ve looked and most are + 20 offset or worse. The +20 with a 9” wide wheel means it will stick out 1.75” more than stock. I’m wanting a 17” wheel and either 35x11.5 or 35x12.5’s.
The salta is the best wheel I can find with an offset of +27. However I was told I need a tire that’s rated at 125 vs 121. So I can’t find this unless I step up to a 18” wheel.
Do I need to run 125 load rated tires? I want Load E tires. Looking at Toyo At 2 or AT3 tires.
