BlueXWA
51000 miles on BlueX .... Seven seconds of starter and engine engaging/turning over and no start...wait a few seconds and then repeat and it starts... No engine lights (CEL)... I will use the amateur OBD II scan tool today...two pathways to go down...1. sensors like cam shaft and crank shaft position, MAF, coolant temp and ECU...I suppose coil packs and plugs.... 2. Fuel pump, filter, injectors..... Has anyone else had this difficult to start problem and what solves it... I suppose I will have to go to the pros with the tools to diagnose the sensors... I don't want to get stranded in the mountains... ... What if the battery is just slightly weak at turning the starter over and there is a timing issue... Wow..if so this system is very sensitive...
